 How to break in engine >
Old 01-14-2006 | 05:56 PM
Mchwind Chimes's Avatar
Default How to break in engine
the engine is an os .46 fxi. how do i break it in right
Old 01-14-2006 | 06:12 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: How to break in engine
Mchwind Chimes,
The best way to break in any engine is to follow the instructions in the manual that comes with the engine. If you follow these instructions you can't go wrong. If for some reason you don't have the instructions that came with the manual you can find an online copy here, [link=http://www.osengines.com/manuals/index.html]OS Engines Manuals Online[/link]
Here are the instructions copied from the manual for the OS 40 LA
RUNNING-IN ( "Breaking-in" )
All internal-combustion engines benefit, to some degree, from extra care when they are run for the first few times - known as running-in or breaking-in. This is because the working parts of a new engine take a little time to settle down after being subjected to high temperatures and stresses. However, because O.S. engines are made with the aid of the finest modern precision machinery and from the best and most suitable materials, only a very short and simple running-in procedure is required and can be carried out with the engine installed in the model. The process is as follows:
1) Start the engine and, with the throttle fully open, open the needle-valve an extra half turn (180°) from the optimum setting. This will produce a rich mixture that will result in cooler running. Allow the engine to run out a full tank on the ground. (Avoid dusty surroundings.)
2) Now fly the model with the needle-valve re-set 20- 30 degrees open from the optimum setting ( i.e. 40-60° from the highest rpm setting ).
3) Close the needle-valve very slightly on successive flights so that the engine is running on its optimum needle setting at the fifth or sixth flight.
I hope this helps
Ken
Old 01-14-2006 | 07:00 PM
Just started my Nexstar OS 46 today for initial break in. Followed the manual. I secured the tail with a piece of rope to a fixed object then cranked it up. Manual said to let it run for one minute at full throttle and the every ten seconds turn the adjusting screw within the range of motion from rich to lean for a full tank. Worked better than expected as I have broken in many nitro engines on my ground vehicles but this was much easier. Now I need to go to the next section of the manual to make sure it does not stall out upon applying full throttle etc...
Old 01-15-2006 | 12:34 AM
w8ye's Avatar
My Feedback: (16)
After your first run of the LA 40 , you should go over the engine and make sure each bolt is snug. Do this after the second run also and it should stay tight after that.
Enjoy,
Jim
Old 01-15-2006 | 11:56 AM
fly the airplane to 600 feet and do a maximum speed dive into concrete. whoops thought you said break not break in nevermind!
Old 01-26-2006 | 08:44 AM
lol, funny guy
not
j/k lol
