Transmitter questions
NJ
Just getting started in RC and naturally my interest is split between opposite ends of the spectrum, sailplanes and helicopters. I'm starting with a Blade CX helicopter, that comes RTF with a TX. Until I move up all bases are covered with the heli. On the sailplane end my instructor has recommended I start with a Zagi, due to their nearly indestructible nature, and all around good fun. Trick RC sells the Zagi in several combos. One includes a Hitec Neon FS 3 radio. The radio, which seems to be a high quality single stick unit, covers everything I can do with a Zagi and most beginner sailplanes, but, has limited move up capability. Everything I've read says go cheap on the first plane, but, not so on a first radio. To that end, I'm looking at several mid range radios. They are the Hitec Optic 6 and Hitec Eclipse 7, as well as the Futaba 9caf.
Here's my question: As I read the description of these radios it mentions that they have airplane/sailplane/helicopter programing capabilities. Does that mean that each of these radios comes with the programing for each pre-installed? So, as I move up, any of these TX could fit the bill as I move between helicopters and gliders? Or, does it mean that the radio is capable of being programed for each, but comes only programed for one? Do I need two radios? Lastly, the Hitec tx are available with a spectra module that allows frequency switching. Is this something I should get if I go Hitec? Thanks for staying with me on my first post here
TX
Most radios (computer radios) have at least the basic programming for helis and airplanes, and some add sailplanes built in. Yes, the basic programming is there. When you set up your aircraft, you tell the radio what kind of aircraft it is, and you'll have certain options specific to that type of aircraft. I don't know about the two hitec radios that you mentioned, but I'm pretty certain the futaba nine channel will have all three programs.
BC, CANADA
Yes... each radio will have the programming installed... you just have to make a menu selection to get the features you want. As for the Spectra... it's certainly worth considering. It means you can change channels at will. I don't recall what the price difference(Spectra vs non-spectra version) is but I don't think it was all that much....
