 Spraying latex >
Spraying latex
Spraying latex
Old 02-24-2006 | 06:55 PM
Default Spraying latex
I would like to apply latex (Sherwin Williams) with a spray gun. I have a gravity feed HVLP gun and thined the material as much as 50/50 but cannot avoid the material coming out in large droplets(spatters). I have tried various air preasures as well as volume adjustments. What am I doing wrong?
Laurence
Old 02-25-2006 | 07:30 AM
Digger44's Avatar
Default RE: Spraying latex
Just do a search and you will find several threads on the topic, I used "spray latex" as the search term and this is one example of the results. [link=http://www.rcuniverse.com/forum/m_3704624/anchors_3704624/mpage_1/key_spray%252Clatex/anchor/tm.htm#3704624]LINK[/link]
Old 02-25-2006 | 08:22 AM
Digger44
Thank you for the tip. I am kinda new here and your suggestion gave me some new direction with the forum.
I found a lot of answers to my question.
Laurence
Old 02-25-2006 | 02:48 PM
w8ye's Avatar
My Feedback: (16)
My experience with epoxy and latex is that it needs to set a little bit after the thinner is put in and then stirred again before spraying to keep the mixture even.
Enjoy,
Jim
Old 02-26-2006 | 03:34 PM
Campy's Avatar
ORIGINAL: Laurence-RCU
Laurence
It sounds like the paint is not thinned enough. I normally thin latex to a consistency about halfway between milk and cream. I have had my best results at 25 - 30 psi.
Here is a little "How To" on painting with latex.
File Type: txt
