Sig Kadet Senior
Banned
The .40 will be adequate, as long as you don't exceed the weight that the plane's supposed to end up as listed on the box. If you exceed the list weight by less than 1 lb, go to a .46. If you exced the weight by up to doubling it... you need a .60. If you intend to ever add a bomb drop or to potentially tow sailplanes, go witht he .60 anyway.
The combination of ailerons and flaps, you'll want to do in a manner similar to the Kadet Sr I have. E-mail me and I'll send digital pics.
Banned
With no dihedral, the wings look like they are drooping. With 1 inch under each wingtip, that illusion goes away, and the wing appears flat. That gives the bennefits of flattening the wing, and the plane still looks good.
Another interresting modification... change the shape of the tailplanes, and the Kadet Sr looks like a Piper Tri-Pacer. Just add the struts.
Its easy to change the shape since the tailplanes are built up from sticks. Just keep the same total area on the surfaces. This would have the fin moved back a bit, and the elevator split, requiring a Y elevator pushrod, or dual elevator servos.
