 saito 82 in a trainer? >
Old 04-08-2006 | 04:49 PM
Default saito 82 in a trainer?
Have a kangke trainer in need of an engine. I was thinking about a saito 82. It balances the plane out without any weight. Any reason i should not use this large of a motor? Would like to buy it and use it later on another plane.
Old 04-08-2006 | 05:07 PM
Default RE: saito 82 in a trainer?
This engine is about the same weight/size as .46. Nothing wrong with using it in a trainer though this engine does like to swing larger props.
Old 04-08-2006 | 05:38 PM
TimC's Avatar
xstew, I ran an O.S. 70 Surpass in a trainer. It worked great and sounded good. The tank I had in the trainer for a .46 two stroke was plenty big enough for the .70 four stroke.
Old 04-08-2006 | 06:43 PM
My Feedback: (9)
Yeah but you should see what a saito 82 likes to drink. A 10 ounce tank should gove you roughly 8 minutes flight on a trainer. I say this because you will only need around 1/2 throttle. I know on my cap580 with the .82 and 10 oz tank got me around 5 minutes with a little reserve. But my 580 is aerobatic and I love vert, so I had a lot higher consumption rate.
Sean
