 Heat Gun >
Heat Gun
Heat Gun
Old 04-14-2006 | 03:10 PM
JollyPopper's Avatar
Default Heat Gun
Does anyone know what temperatures a run of the mill heat gun used to shrink Monokote, Ultracote, etc. achieves at the nozzle? I ran across a commercial heat gun for such things that has two settings, the lower in the 650 degree range and the higher in the 1000 degree range. It sells for $15.90 and looks very similar to our guns. I was just wondering what kinds of temperatures our guns achieve. Thanks, folks
Max
p.s. This is a NIB gun.
Old 04-14-2006 | 03:29 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Heat Gun
Jollypopper,
Those types of "commecial" heat guns get way too hot for out applications. The heat guns that we use for shrinking covering will run ~400°. While you could use a gun like you mentioned it would more than likely be more trouble than it's worth because it would be too easy to burn or melt the covering material. It $15.90 it's not much of a bargain either because you can get a Hobbico heat gun at Tower Hobbies for $11.99. [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJD39&P=ML[/link]
Ken
Old 04-14-2006 | 03:41 PM
Ken:
That confirms pretty much what I was thinking but just wanted to check. I have a Hobbico gun, but it does not seem to get to the temperature that is necessary to shrink some films. I have never, for instance, been able to burn a hole in MonoKote, no matter how long I hold the gun on it, and as a result, I don't shrink the film as much as I would like to. Fortunately, about 95% of what I do is done with an iron, so the gun is really a non-issue. Thanks for the input.
Max
