 Engine start >
Engine start
Engine start
Old 04-21-2006 | 10:55 PM
Default Engine start
I have a 1.20 engine that I found at the weak signals event and would like to start it before I mount it on my plane (because it will be a pain to put it on if it won't run in the first place). Does anyone have any Ideas on a mounting rig I could set up.
Thanks, Dave Trimmer
Old 04-22-2006 | 06:28 AM
Default RE: Engine start
By asking about a "Mounting Rig", are you asking about a test stand? If so, look in the Tower Catalog, or go to their website www.towerhobbies.com and you can easily find what your looking for. They are simple to make, if you have basic skills. If your not asking about a "Test Stand", you need to clarify what you ARE asking.
Old 04-22-2006 | 06:43 AM
Dave,
It's an excellent idea to run any engine on the ground, away from the flying field and all it's distractions and temptations, before you fly it. Any new engine or used one really ought to be sorted first at home on a test stand.
I use scrap wood to make a very solid, strong motor mount. Most are just a slot cut into a piece of 1x6, for the engines that're bolted into your everyday beam mounts. I've also made a setup that will take motor mounts bolted to it so I can mount the engine on the mount that's going into the model. But whatever works for you.....
Just make sure that the entire rig is solid. My pieces of 1x6 are held to a heavy bench with a through bolt and a C-clamp. And they've all got a couple of eyelets to rubber band a tank solidly in place.
Almost every engine benefits greatly from being first run somewhere other than at the flying field just prior to it's first flight. You're not chomping at the bit to fly and if the engine is a little balky at home, you have all the time in the world to sort it out. At the field, you'll be pressured to stick the sucker in the air. And at home you won't have the "experts" gathered around telling you, "it sounds good enough to fly" when it sounds like crap.
A decent test rig is worth it's weight in gold..... if you use it, that is.
Old 04-22-2006 | 08:18 AM
rclement's Avatar
Here's some pics of a simple to make test stand. I just used an extra engine mount that I had. The darker looking spot on the rear brace is a hole drilled through the 2x4 so that I can pound a chunk of rebar into the ground. The whole thing probably took me 10 mins. to make. That's a Saito 91 mounted on it with a 15" prop.
ID:	449347   Click image for larger version
