 New what do you think >
Old 05-04-2006 | 02:31 PM
andrewtexas123's Avatar
Default New what do you think
Hi i am new to airplanes alghough i have flown cheap 2ch foam airplanes. I have found two good airplanes and i want your oppinon if you think i should get some thing else i would be glad to hear. But i am on a tight 200$ buget. the first one comes with a flight sim and brusshlees moter with lipos. the seconed one has brusshless and lipos as well. also what one is easer to fly as a begginer and then start my training at airfield.
http://awlhobbies.com/osCommerce/cat...27ccf918f8034b
and the seconed one
thanks for input and suggestions
Andrew
Old 05-04-2006 | 02:43 PM
Default RE: New what do you think
Neither of these planes would be particularly easy for even an experienced pilot to fly. Unfortunately, easy planes for beginners don't look that good.
Old 05-04-2006 | 02:44 PM
Missileman's Avatar
Neither, both of your choices are advance aerobatic aircraft and you would have a very difficult if not impossible time learning to fly with either one. It doesn't even say what radio comes with them and would most likely not be compatable with any possible instructors radios for buddy box uses.
If electric is what you want I would recommend something more like this:
http://www2.towerhobbies.com/cgi-bin...I=LXJKU3**&P=0
Old 05-04-2006 | 02:50 PM
how about this one
Old 05-04-2006 | 03:24 PM
ptmac3's Avatar
No. Notice where it says:
"This T-34 model is a perfect model for transition from a trainer into more advanced aircraft, yet is still very mild mannered. It has 4 channels, giving full control of throttle, rudder, elevator, and ailerons."
That pretty much sums it up. You need a high wing primary trainer type aircraft to start.
Old 05-04-2006 | 03:27 PM
any sugestions
Old 05-04-2006 | 03:40 PM
TheParrot's Avatar
This is a good suggestion
ORIGINAL: Missileman
