 New guy with questions >
Old 05-09-2006 | 02:54 PM
Default New guy with questions
Hello all,
I'm a new guy to RC and have a few questions.
1- I'm looking at buying a Lanier Explorer 40,or a Hobbico Superstar Select.What would be the better one,or is there better one that i need to be looking at?
2-As far as motors,what would be better Ball Bearing( Super tiger,GMS ),or Bronze Bushing( OS),or is there a better one out there?
Thanks for your help.
Old 05-09-2006 | 03:03 PM
carrellh's Avatar
Default RE: New guy with questions
A good first step would be to contact a nearby RC club and talk to their instructors about getting started
Put in your zip code or city/state on this page and see if there are any clubs within 25 miles or so
http://www.ama-dist-8.org/Clubs/Locator.php
Some clubs have trainer planes that you can use until you solo. Others require you to have your own plane.
There's a club in Helena
Old 05-09-2006 | 03:29 PM
Campy's Avatar
ORIGINAL: flyin fish
Hello all,
As Carrellh said, Step 1. Contact a local club.
Trying to teach yourself to fly has a very steep learning curve and can get quite expensive very quickly.
As for your questions.
See what the instructor at your club suggests. FWIW - MOST trainers fly pretty much the same.
As for an engine, I suggest a ball bearing 46 engine. The difference in cost between a bushed engine and a ball bearing engine is not that great, however, the ball bearing engine is going to provide almost twice the power of a bushed engine. In addition, the ball bearing engine will definitely be useable for your 2nd (or more) plane where the bushed bearing engine normally doesn't have enough power for anything but a trainer.
As for brands of engines..... From personal experience I can highly recommend (not in any particular order) OS 46 FX/AX, Thunder Tiger Pro, Evolution 46 NT. These engines are very user friendly. By user friendly I mean than 99%+ of them are going to run great right out of the box with little or no "fiddeling" needed to run well. These are ABC type engines so the breakin time will be minimal before you can go fly.
A tip for you....while you are learning, use a Master Airscrew prop (the black ones ). They are a lot more tolerant of prop strikes than other brands.
Old 05-09-2006 | 03:40 PM
Also from personal experience, I can add the Webra Speed and Super Tigre.
If you're looking for an ARF trainer, look at the Sig Kadet, too.
Dr.1
Old 05-09-2006 | 03:53 PM
Missileman's Avatar
I will second the SIG Kadet Senior, what a wonderfull plane to fly.
Thunder Tigre Pro .46 engine runs like a dream with plenty of power to spare.
Master Airscrew prop has had 3 ground strikes (due to wind gust when sitting on the runway) with no damage whatsoever (Did scare the heck out of a family of moles nearby )
I will also reiterate, get with a local club and get a qualified instructor to help you along, you won't be sorry you did.
Old 05-09-2006 | 05:59 PM
Thanks for the help,i've been to a club not too far from me and hope to join soon.
Old 05-09-2006 | 06:19 PM
I like the hobbico avastar select. It is a good trainer and as your flying skills improve the plane can and will make a good 2th plane. I still fly my avastar select after 7 years in this hobby. It will almost knife edge . It will hover in 3D with a 12-4 prop. Flat spin and waterfalls too. Best of all it comes ready to fly......for about $350.00 All you need is fuel and a glow stick... Avastar Select has a semetrical airfoil. Most trainers are flat bottom which mean that don't like flying inverted. I have 36 planes and my avastar always go to the field every time I do...
Old 04-07-2008 | 03:25 AM
Hello, where can i get the alaron controls... Servos to ailarons for the avastar
thanks
Brandon
Old 04-07-2008 | 05:36 AM
CGRetired's Avatar
Where can you get aileron controls? Your plane either has them or it doesn't. You just don't "get" aileron controls.
Old 04-07-2008 | 10:37 AM
Missileman's Avatar
ORIGINAL: ultra_stick
thanks
Brandon
What you need, I think from the vague description, is a 12" or so piece of 2-56 threaded pushrods
http://www3.towerhobbies.com/cgi-bin...?&I=LXK064&P=M
Keepers
http://www3.towerhobbies.com/cgi-bin...?&I=LXK086&P=M
and a couple of clevis'
http://www3.towerhobbies.com/cgi-bin...?&I=LXK076&P=7
Old 04-07-2008 | 11:46 AM
Thanks, I bought the plane used on here.
Brandon
Old 04-07-2008 | 01:06 PM
Brandon
http://manuals.hobbico.com/hca/hcaa2016-manual.pdf pg 7 & 8 show how to connect the ailerons on a Avistar.
Old 04-07-2008 | 03:10 PM
Hello all,
Hello "New guy"
Sounds like you're off to a good start with some good advise. When you get ready for batteries, look us up on www.superbatterypacks.com, take note of our unique ONE YEAR UNCONDITIONAL GUARANTEE, or for more info you can always call or email me at [email protected] or 818-222-4499.
Good luck,
Lew
Old 04-07-2008 | 03:28 PM
Apparently Lew just joined just to post an AD. Do you guys allow these types of posts in your forum?
