9303
Old 05-20-2006 | 05:26 PM
Default 9303
can my 9303 jr tx scan rx to same channel as tx is on?ill break it down lets say the rx is channel 48 and my tx is 55.can i scan it to work together?
Old 05-20-2006 | 05:43 PM
bubbagates's Avatar
My Feedback: (32)
Default RE: 9303
not with the stock module in the TX. Either replace the module in the TX with this one.
http://www.horizonhobby.com/Products...ProdID=JRPTXMS
Or replace the crystal in the RX with the matching channel in the TX
You could also buy the SYnth receiver
http://www.horizonhobby.com/Products...ProdID=JRPR790
or this one
http://www.horizonhobby.com/Products...rodID=JRPR2000
It is against FCC regulations to change the crystal in the TX
Old 05-21-2006 | 06:13 PM
Default RE: 9303
thanks bubba.i think ill just go with the scan select rx.cause ill need to buy a receiver anyway with every new plane.but can i buy a regular rx and just tell them my channel on tx and they will send me rx with same channel as my 9303?
Old 05-21-2006 | 06:29 PM
The Ghost's Avatar
Default RE: 9303
If you have to buy a new reciver just get it on the same chanel as the TX and your problem is not a problem any more.
Cheers.
Old 05-21-2006 | 08:15 PM
Default RE: 9303
thanks guys i have figured out the electronics now.now i just need to work on my landings
