 starter/hub >
starter/hub
starter/hub
Old 05-23-2006 | 06:17 AM
Default starter/hub
Hi all;
DQOTD: I'm putting together a H9 Cub/OS 70. I'll use a hub instead of spinner to look "right". With my starter, do I simply reverse the rubber insert when starting an engine with a hub?
Thanks!!
CB36
Old 05-23-2006 | 07:06 AM
My Feedback: (13)
Default RE: starter/hub
Yes, you can reverse the starter insert. You can also buy an insert with an extra-small hole in it.
Old 05-23-2006 | 08:45 AM
You could also buy a starter insert meant to work with a bare prop. Not sure how it would work with oversize prop nuts/hubs.
http://www2.towerhobbies.com/cgi-bin...?&I=LXLW07&P=0
What type of "hub" are you using?
Old 05-23-2006 | 10:28 AM
Ken Erickson's Avatar
Here is the insert for "Safety Hub"s and "Heavy Hub"s.
http://www2.towerhobbies.com/cgi-bin...?&I=LXFT97&P=M
However, I prefer to purchuse at the Local Hobby Shop
Ken, AMA 19352
