 help with elevons >
help with elevons
help with elevons
Old 06-18-2006 | 08:11 AM
z12
Default help with elevons
hi, i have just bought a flying wing to get me into electrics and i am having trouble setting up the eleveon. I have a futaba 6exa, and have switched the w.mix to el like it says in the manual, and have pluged the left elevon in to channel 1 and right into channel 2, my problem is when i press across on the right hand stick (which is normally alerons) both of the servos move in the same direction, like a rudder, i have tried changing the channels on each wing but the servos just go in opposite direction, can someone help me please?
Old 06-18-2006 | 08:15 AM
My Feedback: (13)
Default RE: help with elevons
you need to reverse one of the channels. then when the right stick is moved left/right, the surfaces move in opposite direction. when you move the right stick forward/backward, they move in the same direction. there are 4 combinations of reversing and two combinations of plugging-in. two of these 8 combinations will be right, I think.
Old 06-18-2006 | 08:17 AM
piper_chuck's Avatar
My Feedback: (12)
Have you tried reversing one of the channels?
Old 06-18-2006 | 08:30 AM
z12
i just reversed one of the servos but now the up/down is inverted (up IS up down is DOWN)
Old 06-18-2006 | 09:25 AM
My Feedback: (13)
So now swap the two servos wires (ch 1 and ch 2). as I said earlier, there are many combinations. There will be one (or two) combinations that will be right.
