 0S 91 2 STROKE MUFFLER >
Old 07-07-2006 | 01:23 PM
Default 0S 91 2 STROKE MUFFLER
I have a cap sport with a os 91 2 stroke and the pitts muffler lost one of its down tubes. It looks like it just fell off. Its quite a bit louder but still seems to run ok. Should i replace the tube or just leave it alone. Will it develope enough muffler press at idle? Any ideas on how to attach the new tube (weld,jb weld??)
thanks
Old 07-07-2006 | 03:02 PM
Default RE: 0S 91 2 STROKE MUFFLER
What type of metal is it made out of? Brass, stainless, steel, alum, thick, thin, cast???
Old 07-07-2006 | 03:06 PM
ALUMINUM, THIN
Old 07-07-2006 | 04:04 PM
It probably requires a good (skilled) aluminum welder but it would most likely be cheaper to buy a new muffler.
Old 07-09-2006 | 03:35 PM
has anyone had any luck repairing these mufflers
Old 07-21-2006 | 08:52 PM
I belly landed the same engine with a pitts muffler and riped out one of the pipes. I purchased an industrial grade epoxy at made for metal and glued the pipe back on. Ive got more than 5 flight and its still holding just fine.
Dave
