 How do i make the flaps into ailerons? >
Old 09-16-2006 | 04:04 AM
Default How do i make the flaps into ailerons?
i have a golberg hot stik 40, and i want to just make the flaps into ailerons, so i have a Y cable going into ailerons, then for flaps i have a Y cable going into Aux, how do i set it up so that the flaps act the same as ailerons? i really dont see what the point of flaps are
Old 09-16-2006 | 06:01 AM
MinnFlyer's Avatar
Default RE: How do i make the flaps into ailerons?
Well, the nice thing about flaps is that they create more life, thereby allowing you to fly slower on landing. However, if you don't like them, you could plug 2 Y cords into the Aileron Y cord. That will give you 4 aileron jacks to plug the servos into
Old 09-16-2006 | 06:20 AM
Mr67Stang's Avatar
I would if you have a computer radio put a Y in Channel 6 and another in Channel 1 and set up flaperons with 0%. that should leave you with standard ailerons.
Old 09-16-2006 | 06:21 AM
Mr67Stang's Avatar
And look up "CROW" as it pertains to R/C flight and you may change your mind.
Old 09-16-2006 | 07:39 AM
krossk's Avatar
My Feedback: (27)
Or just go to Horizon Hobbies and download the manual for the Ultra Stick 40 - It has complete programming and setup info for most common computer radios.
Old 09-16-2006 | 06:52 PM
On my ultra stick, I just used one Y for left and one Y for right, (2 servos each side), and plugged them into aileron and aux 1. You could even Y the Y's into a Y and use only one channel, but you may need a spool for all that wire..
Old 09-16-2006 | 07:47 PM
thats how i have it now, but it thinks te aux one is retracts, im not sure how to get it to ailerons
Old 09-16-2006 | 10:34 PM
What TX?
on JR you just slave aux1 to ailerons and you're done.
Old 09-17-2006 | 12:17 AM
Cyclic Hardover's Avatar
ORIGINAL: MinnFlyer
More "Life?"
Old 09-17-2006 | 08:08 AM
MinnFlyer's Avatar
Ooops, "LIFT"
Old 09-17-2006 | 10:01 AM
cyclic hardover,
LIFT=LIFE LOSS OF LIFT=LOSS OF LIFE. Basic aerodynamics. As a helo pilot you should be very aware of this principle.
Regards,
doubledee
