 Cool online thrust caculator >
Old 10-17-2006 | 07:29 PM
Default Cool online thrust caculator
[link=http://www.bmaps.net/]Thrust calc.[/link]
Can anyone explain how to use it ( IOW how to make it work on a PC ) ?
I opened it with an evaluation version of Win Zip ( Do people really pay for that? ). Then what do I click? I get a bunch of codes etc. I don't know what to do next.
Old 10-18-2006 | 06:02 AM
rwright142's Avatar
Default RE: Cool online thrust caculator
Use WinZip and extract all of the files in a folder and double click the "Setup.exe" file to have it install on your PC.
As for WinZip, I don't use it - I use [link=http://www.7-zip.org/]7-Zip[/link. It is free and has more options and is also compatible with .zip files.
Old 10-18-2006 | 07:27 AM
CGRetired's Avatar
It isn't that cool. It wants to change internet explorer settings. Nope... not a good one at all.
Old 10-18-2006 | 09:52 AM
rwright142's Avatar
I did not see any add-in for Internet Explorer - do you mean Windows Explorer? If so, WinZip does the same thing. For example, you right click on a file and have options to add to a zip file, etc.
To each their own. I have used both and prefer 7-zip.
Old 10-18-2006 | 03:06 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Ok, too many people still think they need to download a separate program to extract zip files. If you have Windows XP you can create and extract zip files directly in Windows Explorer without having to get an extra program. I can't even begin to tell you how many of our clients don't know this little fact, and some upset after they actually paid for a copy of WinZip.
Anyway, if you have Windows XP use Windows Explorer (or My Computer) and navigate to the zip file location on your hard drive. Right click on the file name and select "Extract All". This will open up the zip file extraction wizard which will walk you through extracting the file. Once you have the contents of the file extracted then you can run the setup utility which will install the program to your computer.
Hope this helps
Ken
Old 10-19-2006 | 07:22 AM
what RCKen says plus...........
And you don't even have to extract anything to see what's in the zip file or work with the enclosed files in one. Just go into it like you'd go into a folder. I find this capability as much value as having XP do the extractions.
Old 10-19-2006 | 11:36 AM
rwright142's Avatar
Good point.
You don't need WinZip or 7-Zip just to view/extract/create zip files.
XP calls them compressed (zipped) folders.
Old 10-19-2006 | 12:58 PM
RVM
WinRAR > all other compression utilities.
