 Please help with radio equipment >
Old 10-21-2006 | 06:28 PM
nickrummy's Avatar
Default Please help with radio equipment
A few months ago I purchased an older 6 channel transmitter from ebay for cheap and have been researching trying to figure out what I have to buy to get it working. I'll be using the radio for a tank I've been building. I figured I would ask in this forum since it's an aircraft radio.
The radio is a Futaba T6XA. I searched for manuals online and the only one I can find is a 6XA which I would imagine is the same thing. What I'm missing is a receiver and receiver crystal. I have a crystal in the transmitter that is on 50.960 (which they say is 08) Here is a link to the manual.
http://www.futaba-rc.com/manuals/notes-6x.html
It says it came with an R127DF receiver. The problem I'm having is that there are low bands and high bands? Low band says from channels 11-35 and I need 08.....
I found this flight kit.
http://www2.towerhobbies.com/cgi-bin...?&I=LXZW66&P=7
Then if I get this crystal (the 08 crystal) I would be ok correct?
http://www2.towerhobbies.com/cgi-bin...56&FVPROFIL=++
I'm just confused as to all the bands and fequencies and what will work with what. I don't even want the 3003 servos or battery in that flight pack but its the only thing I can find with that receiver in it.
Thanks in advance for the help!
Nick
Old 10-21-2006 | 07:17 PM
Default RE: Please help with radio equipment
nickrummy,
The 50mHz band, channels 00 thru 10 are reserved for amatuer radio operators and an amatuer radio license is required. This is one of the pitfalls of buying from where you bought your radio. Not only is it illegal to use the radio without a ham operator's license it is also illegal to change the crystal in the radio without having it retuned.
See this link: http://rcservice.hobbypeople.net/faqs/freqlist.htm.
It will tell you what you need to know.
If there is anyway you can exchange it for another radio tuned to channels 11-60 I would recommend you do so.
Sorry about that, someone else may have another solution.
Regards,
doubledee
Old 10-21-2006 | 07:23 PM
Missileman's Avatar
when you do get a proper radio for your tank You need a 75 Mhz radio, aircraft radio in the 72 Mhz range is for aircraft use only. 75 Mhz is for ground use.
Old 10-21-2006 | 07:33 PM
nickrummy's Avatar
That was a broke link.... That really sucks! I'm not sure if I can sell it then and get something else or what. Thanks for the clarification!
I can't exchange the transmitter. I bought it without obviously doing enough research. I'll either sell it or get a license I guess. (after I read and see what that would involve.)
ORIGINAL: doubledee
nickrummy,
Regards,
doubledee
Old 10-21-2006 | 07:36 PM
nickrummy's Avatar
missileman, do you have a recommendation on a 75mhz surface radio that is 6-channel?
Old 10-21-2006 | 08:12 PM
Missileman's Avatar
My friend has a Futaba 6EXA 75Mhz he uses on his tank.The hobby shop had the left stick set up to return to center at no extra charge.
Old 10-21-2006 | 10:58 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Nickrummy,
Sorry to hear what happened with your radio. Hope you can find a way to get a bit of money back out of it. If you are looking for a radio to operate a tank with I would suggest that you check out the RC Tanks forum here on RCU. You can find that forum here: [link]http://www.rcuniverse.com/forum/forumid_369/tt.htm[/link] . I know that a lot of the tankers use different type of radios to control the various functions on their vehicles, and they would probably be able to answer your questions better than here.
Hope this helps
Ken
Old 10-22-2006 | 01:59 AM
Ham licenses aren't nearly as hard to get as they used to be. You only need the lowest ranking license which I think is the Technicial class. It involves mostly learning about electronics and antennas, as well as what bands are for what. Used to be you had to do 6wpm of morse to get ANY ham license.
Old 10-22-2006 | 09:26 AM
Sorry about the link. If you want to check it out just go to www.hobbypeople.net and look around. You will find it.
Good luck on getting your radio woes straightened out.
Regards,
doubledee
Old 10-22-2006 | 09:58 AM
piper_chuck's Avatar
My Feedback: (12)
ORIGINAL: nickrummy
If you don't want to get a HAM license, Futaba may be able to change the transmitter to surface. This page: http://www.futabarc.com/faq/faq-6xsuper-q54.html shows prices. Send them an email, address is on this page http://www.futabarc.com/service.html , and ask if they can do it.
Old 10-22-2006 | 10:39 AM
nickrummy's Avatar
very awesome idea piper chuck, I'll definitely look into that!
Old 10-31-2006 | 10:40 AM
nickrummy's Avatar
well they can only change from 72 to 75mhz. he said 50mhz is ok for surface use but you need a ham license. I guess I'll look into it and see what it details. If its to much I guess I'll try and sell it.
