What size engine?????? >
Old 01-18-2003 | 06:43 AM
Default What size engine??????
Howdee,
I'm converting a Kyosho Cardinal 177 electric to glow. This model has a 48" wingspan with about 10 degrees dihedral. What is the largest/smallest engine I can use? The glow kit from Kyosho comes with a .10 engine but I have heard the plane is very under-powered. Thanks!
Mike
Old 01-18-2003 | 06:56 AM
Flyfalcons's Avatar
Probably a .15-.25 would be best. A .40 would be way overkill, and quite a bit heavier than a 25.
Old 01-19-2003 | 05:05 AM
A 40 size 4 stroke would be nice in that plane.Plenty of power and sound great too.
Old 01-20-2003 | 04:23 AM
My Feedback: (14)
You could even consider a .30 size 4-stroke.
I have an old Kadet Senorita (63" wing) that flies real well on a .26 4-stroke. Of course, it is an exercise in "flying on the wing" rather than brute power - no unlimited vertical here.
Again, as was mentioned above, check out the weights of all the possible engines. With the dihedral, it sounds like a good trainer type and you don't want to go turniing it into a lead sled.
Take care, and let us know what you end up doing and how it comes out.
Old 01-20-2003 | 04:11 PM
MinnFlyer's Avatar
Better stick to the 15-20 sze 2 stroke. Putting a 4-stroke on a small plane like that could increase the wing loading too much.
Where in MN are you?
Old 01-20-2003 | 06:17 PM
I think I'm gonna try a .20 if I can find a used one.
b.t.w. I live in Hopkins
Mike
Old 01-21-2003 | 05:11 AM
Live Wire's Avatar
Watch the 20 this plane will park fly on 049. Put a streemer on and go for it. 09 to 15.
