 Servo Installation >
Servo Installation
Servo Installation
Old 12-28-2006 | 12:31 PM
mouthpiec's Avatar
Default Servo Installation
Hi All,
Can someone please tell me a good way how to install the servos in a balsa plane?
My concern is to avoid that the screws will loose up.
thanks in advance!
sandro
Old 12-28-2006 | 12:39 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Servo Installation
Position you servo and mark where you want the servo screws to be located at. Remove the servos and drill a 1/16" hole in each location. Use your servo mount screw and screw it into the hole you just drilled to cut the threads into the wood. Remove the screw and then wick some thin CA into the hole. This will harden the threads you cut so that they won't pull out. Make sure the CA is completely cured before you install you servo.
Hope this helps
Ken
Old 12-28-2006 | 12:40 PM
CGRetired's Avatar
Put a small piece of 1/8 ply behind the balsa, cut it to about 1/4" wide by 1" long and CA it in place under the balsa where the screws go, along the inside edge of the balsa. Then drill the holes for the servo using the servo as a template... drill a 1/16" hole. Put a drop of CA in the drilled hole, blow into the hole to clear the hole of excessive CA. Then when the CA cures, put your servo screws in. Make sure that the grommet that comes with all new servo's is in place with the metal (brass) collar facing the right direction (which is with the bevel end down... the bevel end touches the balsa not the screw head). This allows the screw to bottom out on the brass collar and not on the rubber shock mount. This will hold forever.
DS.
Old 12-28-2006 | 12:44 PM
Install hardwood rails or plywood mounting plate supported by side rails. When you drill the mounting holes don't make them too big or the screws will work loose and/or not get a good bite into the wood. Before installing the screws run a couple of drops of thin CA into each hole and let it cure thoroughly (no accelerator) before installing screws. This will toughen the wood. After the CA you may need to redrill to clean up the holes but not a big deal. Plywood should be 1/8" minimum and 3/16" thick preferred.
Old 12-28-2006 | 12:46 PM
CGRetired's Avatar
Yeah.. what he said...
Howz it going, Bruce? Ready for that 777 trip down under?
DS.
Old 12-28-2006 | 12:50 PM
I'm packed. Now I have to make some room on my credit card.[:@]
Old 12-28-2006 | 12:52 PM
CGRetired's Avatar
Jeez.. credit cards.. don't remind me!!!
Old 12-28-2006 | 02:19 PM
mouthpiec's Avatar
thanks for the help.
What is exactly CA. Can I use epoxy?
Old 12-28-2006 | 02:31 PM
Cyano Acrolate (spelling) Super glue thin
No, not epoxy for hardening the wood/holes. OK for mounting the wood.
http://www2.towerhobbies.com/cgi-bin...&I=LXCX42&P=ML
Old 12-28-2006 | 02:35 PM
mouthpiec's Avatar
can i use loctite super-glue?
Old 12-28-2006 | 02:43 PM
The brand is not too important as long as it is super glue and not thread locker.
Old 12-28-2006 | 02:46 PM
mouthpiec's Avatar
thanks to all..
have a happy new year!
Old 12-28-2006 | 02:47 PM
http://www.loctiteproducts.com/produ...d=115&plid=673
this would be good.
Old 12-28-2006 | 07:23 PM
CGRetired's Avatar
Be advised that there are two types of CA. Foam Safe CA and standard CA. Use the Foam Safe CA for foamie electrics. If you use regular CA on foam.. well, it dissolves the stuff and will pretty much ruin your whole day.
DS.
