Wing Area???
NC
Yes it is counted and yes the fuselage produces lift since it turns a flow of air, the same way a flat foam wing does
http://airfieldmodels.com/informatio..._wing_area.htm
http://webpages.charter.net/rcfu/HelpsHints/WACalc.html
http://www.grc.nasa.gov/WWW/K-12/airplane/factors.html
The convention is to measure wing area (including flaps/ailerons) as though the wing was off the plane so it also includes the area taken up by the fuselage. It's a silly idea really but it's the standard everyone uses to get some comparison between models and even to calculate wing loadings. Some argue that it's done because the fuselage itself can develop some lift.
FL
I think DownUnder is right. For most models, the fuselage over the wing isn't going to create as much lift as the wing, but the only way to compare one model to another is by having a standard. So if you count the wing area that isn't creating lift on every model then the comparison will tell you something once you have flown a few models and have an idea of what any give wing loading will do.
My Feedback: (16)
GA
When you calculate wing area, it is wing tip to wing tip.
The fuselage is counted in the calculation.
While this may not be what we want to hear, this is how Wing area is calculated.
I have measured a couple of planes and that is the only way that the published wing area could be derived.
Don't believe us, grab a plane and do it yourself.
