contrler
i have the regular control for parkzone. When i do full blast it wont work but, if i back off a little bit it will work why does it do this? Are all the stuff not plugged in all the way or what?
You might have a problem with the speed controller. Full power might be drawing too much current from the battery and causing the electronic speed controller to cut out.
If your Parkzone plane is fairly new, you should contact the manufacturer for warranty service.
it does the same thing on both battery and when i first got it dident do that
On some park flyers, the ESC and receiver can be combined onto a little controller board.
It sounds like you're having problems with that particular component in your Parkzone airplane.
yeah because i duno what happen but i did this barrow roll and after that all the power went out and sometimes when i connect the battery i have to put it a certain way or it wont work
