 Identify this trainer! >
Old 02-27-2007 | 01:07 PM
Default Identify this trainer!
Can anyone help identify the kit maker and model of this 40-46 size trainer? 60-inch wingspan. This is the only photo I have until I pick it up this weekend. The seller didn't know who made the kit. (Click the link to see it.)
http://good-times.webshots.com/photo...ost=good-times
Old 02-27-2007 | 02:08 PM
pt40crasher's Avatar
Default RE: Identify this trainer!
It is not a pt40.
Old 02-27-2007 | 03:05 PM
-EXTRA-'s Avatar
Kinda looks like an old eaglet or an eagle
Old 02-27-2007 | 05:44 PM
Hopefully when I get it, that decal/logo on the tail will be a clue.
Old 02-27-2007 | 06:11 PM
Lomcevak Duck's Avatar
My Feedback: (14)
Looks to me to be one of the older PT-40 kits.
Things that give it away:
1) The elevator goes through the rudder. My father and my sister both had one of these and I remember the tail feathers. My sister still has hers.
2) The stringers in the wings look exactly the way the kit looked.
3) The rounded fake windscreen should be a solid block of balsa. Doesn't look like any other trainer on the market now.
4) The ailerons do not extend all the way to the wing tip as on most other trainers.
Note that this is the KIT, not the ARF version that GP sells now. The new PT-40 looks slightly different.
-Steve
Old 02-27-2007 | 07:55 PM
PT40 MkII kit
RIP
Old 02-27-2007 | 08:08 PM
flyboy2610's Avatar
If it is indeed a PT40MKII, you have an excellent trainer.
Old 02-27-2007 | 08:09 PM
My Feedback: (14)
The PT-40 MkI kit had a balsa block rounded to shape for the false windscreen and did not have a sheeted leading edge as does the one pictured above.
And either version of the PT-40 flies very well.
Old 02-27-2007 | 09:59 PM
Duck- GREAT WORK! But who is the manufacturer?
I think the rounded, smallish windscreen is the clue and I wondered about that. The PT40MKII picture seems also seems to have a longish- "turtle deck" which doesn't match my picture, but perhaps the older version MkI doesn't. My picture has a flat one piece back behind the wing all the way to the tail feathers.
This is only important to me because if I decide to do any mods at all, I'd like to track down the plans and the balance points.
As another question, once you have done modifications to a plane, what's the general rule about a balance point? The thickest part of the wing, and then trim it out and see how it flies? I may post this as another newbie topic, since it applies to another of my old trainers I'm restoring and updating.
Old 02-28-2007 | 10:15 AM
My Feedback: (14)
Great Planes made/makes the PT-40 series.
Unless you change the geometry of the wing, you should not deviate too far from the manufacturer's recomended balance point. On this plane a good starting point would be about 27-30% of the mean aerodynamic chord (MAC) for stability. Check around in the aerodynamics forum and they can help you out with understanding CG better.
By the way, in stock form this plane is very stable and will make a great primary trainer.
After you learn to fly it well, I had a freind who put a bigger engine on the nose, larger control surfaces, added flaps, and converted it to a tail dragger and made it into a well-behaved bush plane.
-Steve
Old 02-28-2007 | 02:35 PM
I'll second the vote for it being an older PT-40 kit. We had one as a club trainer back around '88 timeframe, and it looked a lot like that one. Great flying plane, I probably taught a dozen people to fly on it.
Old 03-04-2007 | 11:46 PM
Yep I picked it up this weekend. It has been rode hard and put up wet, and I've already stripped off the old layers of wrinkled covering, ready to try to restore it to it's original beauty. While I was with the seller, he also talked me into buying a Super Sporster Biplane for $40, which is beyond my flying skills at this point, but I will enjoy restoring it too.
Thanks for all your help in identifying it.
Old 03-05-2007 | 12:25 AM
You should be able to get a copy of the manual on the Great Planes web site if you want it.
