 Need help for a final choice...... >
Old 03-05-2007 | 07:15 PM
Default Need help for a final choice......
Ok , i decided to go with a RTF warbird from Parkzone for a 2nd plane.
THere is 3 different model , i like them all but cant make my mind.
the P-51D Mustang ??
the Focke Wulf 190 ??
or the Spitfire ??
ID:	635898   Click image for larger version
ID:	635899   Click image for larger version
Old 03-05-2007 | 07:18 PM
bigedmustafa's Avatar
Default RE: Need help for a final choice......
The Spitfire.
It's the newest of the three, so any problems or quirks that occurred with the P-51 or FW-190 are more likely to be worked out of the model.
Old 03-05-2007 | 07:20 PM
That's easy. Go right down the line.
Second plane P-51, Third, FW, and fourth, The Spitfire.
Should take about an afternoon if you take your time.
Old 03-05-2007 | 07:45 PM
ORIGINAL: agexpert
LOL at agexpert!
If I recall, QUESTO has some RC experience. He probably would be smart enough to keep the Spitfire in the box if he instantly shredded his P-51 and FW-190 on their maidens.
Old 03-05-2007 | 07:49 PM
I just couldn't resist.
Old 03-05-2007 | 07:51 PM
LOL , yeah , well im not the best pilot , but i can control the supercub well , can do loop , land pretty well , im ready for the 2nd level.
I read a couple of post and look at some video and comments , look like the spitfire will do the job. well i think?
Old 03-05-2007 | 07:57 PM
YNOT's Avatar
ORIGINAL: bigedmustafa
The Spitfire.
Did they work out that issue with the wing tips?
Old 03-05-2007 | 07:58 PM
I've seen the Mustang fly, it's pretty quick, particularly so if you use a LiPo battery instead of the stock NiMh battery pack. If you've gotten really good with the Super Cub it might be worth a shot, though. What the heck? It's only money.
The only other thing that I can think of that might be a good stepping stone would be something like the Phase 3 Swoop RTF from Hobby People:
http://www.hobbypeople.net/gallery/107116.asp
Flying wings are pretty durable, and the Swoop should be a bit easier to fly than one of the warbirds while still getting you used to higher performance flight. It's a tough call though, there may not be that big of a difference between the Swoop and a Parkzone warbird. If you like the Swoop, try one before you buy a warbird, otherwise go straight to your Spitfire.
Let us know how you do with your warbird.
Old 03-05-2007 | 08:52 PM
Is it me or the Spitfire look lighter than the P51 ?
Old 03-05-2007 | 09:34 PM
Interestingly enough, Parkzone lists the following flying weights:
P-51 - 29 ounces
FW-190 - 28 ounces
Spitfire - 26 ounces
That makes the Spitfire a full 10.35% lighter than the Mustang.
Old 03-05-2007 | 09:36 PM
VictoryRoll-91's Avatar
Spitfire ALL THE WAY. 3 wire servos (Interchangeable), no contest. Plus it looks better imo.
Old 03-05-2007 | 09:51 PM
Look like the Spitfire is the winner , only cost 14$ cad more than the 2 others.
THanks for the helpfull replys!
Old 03-05-2007 | 10:45 PM
Mr67Stang's Avatar
Or buy my like new P-51... so I can get the Spitfire JK; git the Spit. I want one but can't justify it as I already have the Mustang.
