ca hinges
I need some sound advise. Im just getting back into models after 15 years and Ive forgot a lot of things. I have assembled a Sig Kadet Senior Arf. It has ca hinges and I Messed up and got ca glue all over the hinges I mean soaked. Should I go back and redo the hinges before I try and fly it.
thanks Dan
thanks Dan
If they are coated at the joint and have cracked from flexing. Then I would consider redoing them. Think of it this way the extra hour it will take to replace them is nothing compared to a major rebuild in the event a surface lets go during flight. Remember Murphy is watching you every time you fly
Ledbetter, read this:
http://www.rcuniverse.com/reviews.ph...ew&reviewid=55
If you did something that's WAY off base with these instructions, I might consider replacing them.
[B]I need some sound advise. Im just getting back into models after 15 years and Ive forgot a lot of things. I have assembled a Sig Kadet Senior Arf. It has ca hinges and I Messed up and got ca glue all over the hinges I mean soaked. Should I go back and redo the hinges before I try and fly it.
thanks Dan
thanks Dan
This is a little hard to do long distance. Do you have an experienced modeler that can take a look at them?
