 Engine Question >
Engine Question
Engine Question
Old 03-31-2007 | 11:47 AM
Default Engine Question
I have heard that after run oil is the same as automatic transmission oil, does anyone know if this is true or not?
manks
Old 03-31-2007 | 12:34 PM
Default RE: Engine Question
I would not use AT fluid in an engine. If you must use after run oil, use one marketed for that purpose. If you are buring Omega fuel, note their web site where it states NOT to use after run oil
The only time I might consider useing it is if I were going to lay an engine up for several months.
Don
Old 03-31-2007 | 12:39 PM
alot of people use atf booth as afterun and assembly oil.any non gumming oil is better than none.the culprit is the alcohol and the nitro .the nitrol is made from nitric acid.the alchol atracts the moisture in the air and that and the by products of the nitro cause bearings to rust etc.I changed tactis years ago and went with 0 nitro fuels and larger engines[cheaper in the long run] and engines with plain bearings if avaiable in the si9ze I want.then on the last flight of the day I fly at half theottle till the tank runs dry dead stick and use marvel oil .some of my engines are close to 35 years old and still run like new.
Old 03-31-2007 | 02:55 PM
Use Air Tool Oil. You can get it relatively cheap.
Remember that an IC engine is really just an air pump.
Old 03-31-2007 | 03:25 PM
ORIGINAL: manks7477
manks
The standard home brewed after run is 1/2 Automatic Transmission Fluid and 1/2 WD40.
So what you heard was 1/2 correct.
Old 03-31-2007 | 05:50 PM
Knowledgable folks don't use WD40 as after run oil. It is good as a solvent for cleaning crud out and unsticking things, however. I use Rislone which is cheap and works well. Lots of folks use air tool oils. The after run oil at the hobby shop strikes me as very expensive.
Old 03-31-2007 | 06:08 PM
Can you get air tool oil at Home Depot?
Old 03-31-2007 | 07:13 PM
I'm doubting it. Find a NAPA store or something similar. I know NAPA carries it. If you have a major auto shop in your area ask them where they get theirs.
Old 03-31-2007 | 07:31 PM
mscic-RCU's Avatar
Hey Manks:
Originally from Steubenville, where do you guys fly down there? I go home a few times a year, wouldn't mind flying when I'm down there.
Old 03-31-2007 | 07:49 PM
iron eagel's Avatar
ORIGINAL: manks7477
Yes, I have bought it at home depot for my nailing guns and air tools.
Old 03-31-2007 | 09:12 PM
ORIGINAL: mscic-RCU
Hey Manks:
Sorry - I am from Toronto, Ontario Canadam not Ohio, not sure why it says that
Cheers!
manks
Old 04-01-2007 | 08:45 AM
You can go back into your "settings" and correct it. Sometimes when people give advice they need to consider your location.
Old 04-01-2007 | 10:57 AM
Yes some folks use 1/2 tranny fluid and 1/2 whatever oil...dont use WD-40. Marvel Mystery oil or 3in 1 oil is okay. I had a brand new OS 60 that I used after run oil in religiously. I burned out the unused fuel, every time i was through for the day. This engine produced black oil from the git go when I took it apart the bearings were rusty.l Go figure
