Balsa Dent Removal >
Balsa Dent Removal
Balsa Dent Removal
Old 02-20-2003 | 03:15 AM
NOVAflier's Avatar
My Feedback: (21)
Default Balsa Dent Removal
I saw on this board, or maybe another, a technique to remove dents from balsa.. anyone know what it is?
Old 02-20-2003 | 03:42 AM
White vinegar. You can use other types of vinegar, but they will stain the wood.
Old 02-20-2003 | 04:07 AM
Plain ole' heated, vaporized H2O (steam).
Old 02-20-2003 | 04:14 AM
Wet the dent and see if it comes up. For a stronger effect apply a covering iron the the damp site.
Dave Segal
Old 02-20-2003 | 11:02 PM
I wet the area with water,then go over it with a iron,usually one treatment is all that's needed,but after the third time any dent left I'll use a filler then sand smooth.
Old 02-21-2003 | 05:44 AM
Default Re: Balsa Dent Removal
I'm really not a wood worker as far as building homes and furniture.
But I have built up well over a hundred rifle stocks and repared dents for others who dropped them.I also built many canoes and kayaks.
Steam is your best friend when it comes to sucking out dents..
Sometimes a good soaking in very hot water and letting it dry will work out the deeper dents.
GL
Old 02-21-2003 | 01:05 PM
NOVAflier's Avatar
My Feedback: (21)
Well, I did not have any viniger in the house, so I tried a little water with my cover iron, and am was totally amazed. Actually, I was so impressed at how it worked, I went around onto every piece and got everything I could out. What a great suggestion! Thanks guys!!
