 Aileron Mixing >
Aileron Mixing
Aileron Mixing
Old 04-21-2007 | 05:52 PM
Default Aileron Mixing
I just built a Sig EP-42.
I have one of the ailerons plugged into channel 1 and the other plugged into channel 5. How can I make the stick control both ailerons with my Futaba 7CAP.
My LT-40 is set up this way, but its been so long since I set it, I cannot figure it out again. I've tried to find the answer in the manual (cannot locate my manual, so was using the PDF version).
Thanks much!.
Old 04-21-2007 | 08:32 PM
Default RE: Aileron Mixing
Okay, if I remember correctly...you will have to turn on that function after setting the plane up w/that configuraton. Thre should be an option on the transmitter to do that via LCD display menue, I can check.
Old 04-21-2007 | 09:19 PM
It is different depending on if you have a 5 channel RX or a larger RX. Look starting on page 42 of the manual.
NORMALLY Second aileron is ch 5 for a 5 channel RX and ch 6 for a larger RX.
Old 04-21-2007 | 09:40 PM
it is in the flaperon mix section I believe.
Old 04-21-2007 | 09:46 PM
I found it. Thanks much.
