 27 frequency question >
Old 04-25-2007 | 09:07 PM
Default 27 frequency question
I started flying/crashing a Sky Fly with a 27 mh radio on channel 4. I like the radio very well. I just purchased a Slo V and I made sure it was also on 27 mh, channel 4 also so that I could use the original radio which is more conventional to something that I might upgrade to in the future as far as it having two lever action. .
Neither radio will nudge the other planes receiver. Both are on 27 mh and channel 4 but they don't interact at all. What am I missing here?
hershey
Old 04-25-2007 | 09:59 PM
Default RE: 27 frequency question
Perhaps one is AM and the other is FM modulation.
Old 04-26-2007 | 05:44 AM
Or one is positive shift and one is negative shift.
Dr.1
Old 04-26-2007 | 12:06 PM
Or they could be using totally differnet frame rates and timing arrangements.
it's actually more surprising that all the various brands of transmitters using FM-PPM actually do work with each other's gear (except for shift direction). I think that's going to turn out to be the exception rather than the rule in the long term. Between PCM and 2.4ghz, I suspect the days of mix-and-match TXs and RXs may be numbered.
Old 04-26-2007 | 03:30 PM
edberg's Avatar
Parkzone 3ch radios and receivers don't work like "real" radios and receivers, or so I've been told.
