 simulator problem >
simulator problem
simulator problem
Old 04-26-2007 | 10:13 AM
Default simulator problem
I bought this USB cable to connect my Futaba Tx to use with FMS.
http://cgi.ebay.com/USB-Simulator-Ca...QQcmdZViewItem
When I plug in the USB connector to the computer, it begins blinking rapidly and stays that way. The PC doesn't seem to recognize the new device or ask to install driver etc. Any help on how I can troubleshoot this?
Old 04-26-2007 | 10:30 AM
Default RE: simulator problem
lol $5 for the piece, $15 shipping for a few cables. They really get you.
Old 04-26-2007 | 10:40 AM
ORIGINAL: Pete1burn
It finally arrived on a slow boat from Hong Kong. This is the cheapest one I could find. So far, I'm getting what I paid for.
Old 04-26-2007 | 10:49 AM
opjose's Avatar
If it is a TRUE "HID" device, Windows XP will pop up a message about a new device found when you plug in the cable.
You must be running XP or greater. Also turn on the TX with the cable plugged in.
Some PPM interconnects require a driver program, such as JRPROPO, etc. to run, and getting these things to work is not trivial.
Old 04-26-2007 | 09:45 PM
ORIGINAL: opjose
What is a true "HID" device? I'm grasping at straws here.
Hwlp! My only alternative is to actually get stick time at the field with an instructor.
Old 04-27-2007 | 10:55 AM
opjose's Avatar
HID = Human Interface Device
HID is the protocol used for the software interface.
If you find that XP is not recognizing the interface, try going into
Control Panel/Administrative Tools/Services
and START the "HID input service".
Once it's started plug in the interface cable to the USB port on the computer.
Sometimes this will cure the problem.
XP should then recognize the new HID device.
Finally plug in the TX and calibrate the new "joystick" device that XP has detected.
Old 04-28-2007 | 03:45 PM
There are many usb simulators avaliable to buy. You might want to try some fo the drivers for them to see if they work. you can just do a google search for usbsimulator and you can find some drivers.
Old 05-09-2007 | 12:21 PM
I have not received the cord yet, so I have not begun the process of getting it to work, but here is a site that I found in a thread that looks like it gives great info. Check it oot
http://www.tti-us.com/sim/FMSop.html
Old 05-09-2007 | 05:28 PM
Ya know, there is a forum on RCU that specializes in simulator stuff.
http://www.rcuniverse.com/forum/forumid_138/tt.htm
I'd be asking there too.
