 new battery pack help! >
Old 04-27-2007 | 05:04 AM
Default new battery pack help!
Hi,
I am new to rc hobby and need some help to choose a baterry pack please.
a)can I use 5cell (6v) pack with jr receiver? (646pcm) Came from factory with 4.8v pack
b)what size cells I must use with a 60in plane ? I see that the cell s weight between aa aaa and biger type cell isn’t much different.so I must use aa,aaa or biger size cells for my pack?
c)the capacity of the cells. I will need them only for the receiver and servo operation but in the price they have at about 2$ diference. If I choose cells with biger capacity (2600) the 5x2600 will be 13000mah. Is it too much?until now i used a 1100mah pack and it is more than enouth for me. Is it more dificoult to balance the cells in the packs when I charge them?
I see that many smaller capacity aa cels is out of stock. Any suggestions?
I don’t want to charge with 13a at 1c.
I was thinking of 5 cells at about 1000-1500 mah with total of 5000-7000mah to be able to charge them with 7A at about 1c or 2c.
d) the shape of the pack is critical?
e)many users suggest 2 packs with two switches at the same receiver. Is it safe? The packs must be identical and I will need a regulator?
f)nimh or nicd?
the reason i want to change my packs is that they are already 3 years old and i dont risc a crash.
please help me to choose a pack
charger used : ICE
Thanks very much
Achilles
Achilles
Old 04-27-2007 | 05:33 AM
Default RE: new battery pack help!
G'day Achilles,
Ok first off, you can use a 5 cell, 6 volt pack with that RX, sometimes some servos are not suitable for 6 volts.
A 60 inch plane is relatively small, & an 1100 Mah pack will do nicely, unless you are flying with digital servos & flying 3D.
The capacity of the pack, is derived from the capacity of the individual cells, because they are connected in series, so a pack with 1100Mah cells is still rated at 1100Mah, the capacity does not add on.
You will need to charge new packs at 1/10 of its capacity, so an 1100Mah pack should be charged at 110ma. see site, http://members.aol.com/davthacker/balancecharging.htm
I personally still use nicads, because I have had trouble getting NiMh cells that will supply reasonable current, but NiMh packs are good if you can get the good ones.
It is a good idea to replace you batteries about every 3 years, so anything over 1100Mah, up 2000Mah will be good for your installation, remember the larger capacity, means more weight.
Old 04-28-2007 | 07:28 AM
thanks for the help Allan,
i am thinking of buying cells (sanyo nimh hr-3u) and build my own packs.
i am trying to find cells with solder tabs , connectors and everything else i will need including instructions on how to do it.
any good place to find that info?
thanks again
achilles
Old 04-28-2007 | 08:13 AM
P-40 DRIVER's Avatar
Do not build your own packs, It is very easy to damage the cells by overheating them, leave this to the experts. For a standard 60" airplane running 4 or 5 standard servos, 600-700 mil nicad pack will work fine if your not doing a huge number of flights. double that if your going with digital servos. You may want to add a little more NIMH cells. Charge your batteries over night at 1/10 th thier capacity, 100 miliamps for a 1000 miliamp pack. The Pack that came with your radio will probably work fine and thier is no reason to run 6 volts unless your are running a high performance application such as 3D etc. Sounds to me like you have yourself completely confused about batteries. Don't waste a bunch of money untill you understand whats going on.
