 My First Balsa Build >
Old 05-13-2007 | 07:01 PM
mrlikescheese's Avatar
Default My First Balsa Build
I have a Hobbico Superstar trainer that i got last year from our next door nabor that flys. It was all put together and my dad put in most of the radio and engen.
I want to get an easy kit to build for my first build. It seems like kits are a lot cheeper, so i want to learn how to build them. Anyone got any good ideas?
Old 05-13-2007 | 07:25 PM
ChuckW's Avatar
Default RE: My First Balsa Build
Where are you as far as flying skills go? Be honest here. If you are still in the trainer stage, take a look at the Sig Kadet LT-40 or Great Planes PT-40/PT-60. If you are ready for a low wing trainer, check out the Sig Four Star Series, Great Planes Rapture and Goldberg Tiger-2. All of these should be good for a first build. Building is a blast if you are inclined to do that sort of activity to begin with. You'll really enjoy it. You mentioned kits being cheaper though; I disagree with that. They generally are no cheaper than ARF's and often more expensive. By the time you buy glue, wheels, covering and so on, the price adds up quick. That's no reason not to build though. Building is something you do for your personal enjoyment. Try it, you might just get hooked.
Old 05-13-2007 | 07:27 PM
USMC07Seghetti's Avatar
Only suggestion I can think of for you would be to build a trainer.
www.towerhobbies.com <---- They have lots of trainer kits to choose from. Then again you said you already have a trainer so you may not be interested in getting another, You can also look at the Sig Four Star, I have a 4* 60 but I have'nt started it yet. I have read alot here on RCU that it is an easy kit to build for begginer kit builders and the manual is very easy to comprehend, just like the manual for the LT-40 I built.
http://www2.towerhobbies.com/cgi-bin...?&I=LXFG06&P=0 ---- Sig 4* 40
http://www2.towerhobbies.com/cgi-bin...?&I=LXFG16&P=0 ---- Sig 4* 60
http://www2.towerhobbies.com/cgi-bin...?&I=LXFG08&P=0 ----- Sig 4* 120
Just a few suggestions.
EDIT: ChuckW is right about the kit price range, My LT-40 kit and everything to finish it totaled over $500... but then again, I added a couple non-essentials.
-Chris
Old 05-13-2007 | 07:33 PM
Insanemoondoggie's Avatar
If you have a trainer already, I would recommend build an low wing for your next plane. A sig 4 Star builds easily.
Old 05-16-2007 | 08:24 PM
How much are the 40 size Four Stars?
Old 05-16-2007 | 08:28 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: mrlikescheese
Sig Four-Star 40 kit, $79.99 at Tower Hobbies. [link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFG06&P=SM[/link]
Ken
Old 05-16-2007 | 08:46 PM
Fastsky's Avatar
You could also look at the Mid Star for the same price. The kit comes so that you can start flying the plane as a trike gear and then convert to a tail dragger later if you want. I like the Mid star better becaause of the way it flys and its a bit bigger which makes it easier to see. http://www2.towerhobbies.com/cgi-bin...?&I=LXFG07&P=7[8D]
