saito 100 setting
saito 100 setting
hello guys any body no the setting for the saito 100 with 15/6 prop hy just buy this engine use and the setting is not good sorry for my english is not so good but your help is verry appréciated[&:][&:]
RE: saito 100 setting
I use the same engine with the same prop but a Master Air Screw insead of the APC I see in your picture. Carefully turn the needle all the way in then back it out 3 turns. This should give you a safe starting point to begin normal tuning procedures.
