 Alpha 60 reciever >
Alpha 60 reciever
Alpha 60 reciever
Old 06-03-2007 | 09:29 AM
Default Alpha 60 reciever
How do you get to the reciever on an alpha 60. I want to install a Voltwatch2 on it, but its covered in foam. It looks like you take out that screw and slide the piece of wood away from the fuel tank, but im making sure. Those who have this plane should understand what I mean. Sorry I dont have a picture for those who dont have it.
Old 06-04-2007 | 04:34 AM
Default RE: Alpha 60 reciever
That will do it!
Old 06-04-2007 | 05:04 AM
make sure you get everything back in the same spot. It does make a difference where the battery and receiver go as this effects the CG
Old 06-04-2007 | 07:18 AM
I took all that out, but that stuff is in there tight. I did get it out eventually, and hopefullly I put it back right.
Old 06-04-2007 | 07:21 AM
bingo field's Avatar
You can always recheck your CG like they tell you in the book that came with it. That way you will know for sure if it is right. Those Alphas are some good flying planes, and pretty durable. I have had one for almost 5 years, and another for about 4. They have taken a beating, and then some.
