 What the heck am I doing wrong??????????? >
Old 06-19-2007 | 02:33 PM
Default What the heck am I doing wrong???????????
I have wasted several large piesces of monokote trying to cover my tail. but it shrivles and doesn't stick. i've tried it with the clear film up and down. also with different temperatures. can someone give me a hand. this will be my 3rd time covering.
Thanks, dave trimmer.
Old 06-19-2007 | 02:34 PM
BarracudaHockey's Avatar
Default RE: What the heck am I doing wrong???????????
Take the clear film off, that will expose the adhesive.
Old 06-19-2007 | 02:35 PM
plug in the covering iron?
j/k
Ok it has been 15 years since actually built a model, so take what I say with a grain of salt. Having said that you mentioned putting the clear film up (and down). I might be wrong but I believe you are supposed to peel that clear film off of the colored material. The surface between the colored film and the clear film is what you place in contact with the wood (etc). This is the side with the adhesive.
Hope I am right, and this helps.
Darn...Beaten by 1 minute 35 seconds
Old 06-19-2007 | 02:42 PM
http://www.monokote.com/monoinst1.html
Just in case you lost your copy. Sounds like you left the protective clear layer on.[:@]
Thanks each of you I guess i should have thought of that
thanks again, dave trimmer
Old 06-19-2007 | 03:31 PM
JohnBuckner's Avatar
Sounds as though you are using Monocoat brand film since the backing material is clear plastic instead of the paper product used with Ultracoat.
This is an extra benny for you. Save the larger pieces of the clear backing material for a plan protector when building over plans it works wonderfully well in this application and interestingly enought Tower sells dedicated rolls of the stuff for the purposes but you get it for free.
John
Old 06-19-2007 | 03:46 PM
John, he said Monokote in the first post.
Old 06-19-2007 | 04:11 PM
ORIGINAL: bruce88123
Uh OK fine however the tip on using the backing film remains the same and I don,t beleve that was mentioned.
Old 06-19-2007 | 04:19 PM
ORIGINAL: JohnBuckner
Correct and it's a good tip. I've seen it posted in other threads and use it myself. Does work well.
