 3d model what should down thrust be >
Old 07-08-2007 | 09:14 AM
suzonka's Avatar
My Feedback: (7)
Default 3d model what should down thrust be
have a hanger 9 twist 60 arf @ question what should the down thrust on prop be, they seem to have left it out of the manual
Old 07-08-2007 | 10:51 AM
ChuckW's Avatar
Default RE: 3d model what should down thrust be
With that thick, symmetrical wing it is probably zero. If any is required, it's probably built into the firewall. I did have to put a couple washers to add right thrust to my Twist 40 though.
Old 07-08-2007 | 01:14 PM
On a ARF its already built in...if you're still unsure, call tech services, should be in the instructions somewhere
Old 07-08-2007 | 01:26 PM
suzonka's Avatar
My Feedback: (7)
ORIGINAL: jetmech05
thanks but it look s sstright as an arrow the firewall
Old 07-08-2007 | 03:34 PM
j.duncker's Avatar
Zero downthrust and start with a little right side thrust. During the trimming process you will adjust the sidethrust to produce a stable prop hang. [Or slow vertical climb.]
Old 07-08-2007 | 04:08 PM
suzonka's Avatar
My Feedback: (7)
ORIGINAL: j.duncker
[:-]Thanks thats what I want to do get a good prop hang
Old 07-08-2007 | 06:17 PM
broke_n_bummin's Avatar
On 3D and pattern planes and some sport planes, the engine has no downthrust and no latteral thrust. Those angles are built in on scale models and trainers to offset wing incidence and P factor. You add side thrust, and you'll fight with it to do a knife edge or flat spin. You add downthrust, and it won't hover easilly, and you'll have to keep up elevator to fly inverted.
Old 07-08-2007 | 06:47 PM
suzonka's Avatar
My Feedback: (7)
ORIGINAL: broke_n_bummin
Old 07-08-2007 | 06:48 PM
suzonka's Avatar
My Feedback: (7)
ORIGINAL: suzonka
Thanks Ill start zero side or down and see what happens
