 Twin Engine Setup >
Twin Engine Setup
Twin Engine Setup
Old 07-09-2007 | 09:31 PM
Default Twin Engine Setup
I'm curious about how to make a dual engine aircraft.
Would it be possible to have both engines wired and powered on the same channel? Or will that cause a resistance problem such as with stereo speakers? I just want to know before I make something from scratch that I don't fry something out. I'm not the most electronicially minded person so I'm asking first before I regret it
I was also curious if there are any outlets that sell micro kits - setups for planes of 20" and smaller. I notice that some of the REALLY small planes use little actuators...
Old 07-09-2007 | 09:43 PM
DavidAgar's Avatar
My Feedback: (108)
Default RE: Twin Engine Setup
You may want to check out the Twins forum and the Electric forum for some awnsers to your questions. Good Luck, Dave
Old 07-09-2007 | 09:56 PM
Oops. I'm blind. I shoulda seen that earlier. Sorry for the uneeded post.
Old 07-09-2007 | 10:18 PM
For brushed motors, you can wire the motors in parallel with no problems. Brushless motors require two ESCs - one for each motor.
Old 07-10-2007 | 12:43 PM
Great! Thanks for the tip!
Old 07-10-2007 | 05:51 PM
DavidAgar's Avatar
My Feedback: (108)
This thread is being closed as the same question has been asked in the Twins Forum. Thanks Dave
