DuBro or Slimline? >
DuBro or Slimline?
DuBro or Slimline?
Old 03-12-2003 | 08:49 PM
Default DuBro or Slimline?
What do you guys prefer to use as a quick fueller?
The DuBro Kwik fuel valve
the Slimline F1 fuel dots
I haven't istalled one yet, but I am going to insall as soon as you guys advise me as what your preference is
Old 03-12-2003 | 09:02 PM
MinnFlyer's Avatar
The only problem I ever had with quick fuelers is that once I lost the adapter to my fuel pump. That was a big PIA due to the fact that the LHS is a 2 hour drive.
Now I use dots.
Old 03-13-2003 | 01:11 AM
I have also thought about using the quick fuel valves as well and I am still contemplating about purchasing one. I have been turned off though by some for the simple reason that in time (however long that is) will develop dirt inside, or from just normal use not seat which in turn will make them not function as well or at all. They are a bit expensive, to keep replacing. I also agree with MinnFlyer, that once you lose the fuel probe your done. Those probes themselves are much more than just pennies a piece.
BUT...........if you find and purchase a FUEL VALVE COVER, you can then prevent the "FOD" from entering the valve. Nothing will prevent the normal wear and tear. Also if you were to safetywire the probe on you fuel line you have just prevented the loss of that probe by about 95%. (guess-ta-mation).
So you see, that I too am debating, but getting frustrated at the same time in trying to find that little "dust" cover for the valves. Have you found the covers? Hopefully this helps you.
Old 03-13-2003 | 01:17 AM
Three line system, with fuel dot(which will eventualy fail, sooner or later) or three line plugged with an allen head bolt, cut to the shaft. Never leaks, never fails, nothing to loose.
d
Old 03-13-2003 | 02:05 AM
Well, today I purhased the following items: Du-Bro fuel dot, Du-Bro Kwik fuel valve and R/C City Aluminum fuel dot. I have three planes I am going to install these on and experiment with. Thanks for the response guys, I'll keep you posted as to how I make out.
