 Telemaster 40 CG >
Telemaster 40 CG
Telemaster 40 CG
Old 08-22-2007 | 05:15 PM
Default Telemaster 40 CG
Hi Gang,
I have had my telemaster ready to go for some time and now I want to recheck the CG before I take the model out. I can no longer find the plans or the copies that I made. I have the model balancing out at the main spar using about 3oz of wieght along with moving the battery up front. Let me know if this will work out as it is.
Gary
Old 08-22-2007 | 06:20 PM
Default RE: Telemaster 40 CG
On the spar is fine. If you can move the batteries further forward (under the tank) and reduce the weight I'd do that.
