 buddy box >
buddy box
buddy box
Old 08-26-2007 | 04:04 PM
Default buddy box
Hi All
I have a question about the possibility to connect two different transmitters .(to train someone)
in other words , I want to connect a t6exap futaba transmitter to a non futaba transmitter , only using the signal and ground from both .
Old 08-26-2007 | 04:28 PM
armody's Avatar
My Feedback: (10)
Default RE: buddy box
In order to train someone over a buddy box, you need a cord to connect from your Tx to other non Futaba Tx, as Jr's Tx can be connected to Futaba's Tx provided that you have the right cord with right connectors on it. I'm sure you must have understood, some other expert would explain you pretty well about it.
Mody
Old 08-26-2007 | 04:41 PM
Thx armody
I know that there are ready cables to connect different transmitters , but the other non futaba transmitter that I have is not a well known mark and in addition it doesn't have a connector . so that;s why I post the question.
thx a lot
Old 08-26-2007 | 04:53 PM
Put simply, you are trying too hard.
You need to get this set-up:
http://www2.towerhobbies.com/cgi-bin/wti0161p?&I=LZ0243
Old 08-26-2007 | 06:06 PM
what brand is the non futaba? I've never seen a transmitter thay didn't have a buddy cord connectorr
Old 08-26-2007 | 06:19 PM
Bad_Daddy's Avatar
First of all, do you know if your no-name transmitter is positive or negative shift?
Go to here: http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb1.htm and start reading
Old 08-26-2007 | 06:50 PM
Don't re-invent the wheel. Purchase or borrow the correct product or expect to pay for it the hard way.
Old 08-26-2007 | 10:47 PM
armody's Avatar
My Feedback: (10)
You're welcome shreifali.
I knew somebody would come with great solution.
Bruce is someone who I would rather say A SOLUTION PROVIDER who always comes with Proofs of Solution.
Keep it up Bruce, and good luck to you shreif.
Mody
Old 08-26-2007 | 11:56 PM
OzMo's Avatar
the hassle and cost of wiring a non trainer ready radio just isn't worth it. go to EBAY and snag one of many trainer boxes for $20.00.
they are quite common and cheap.
