 weight to engine ratio >
Old 08-30-2007 | 01:24 PM
Default weight to engine ratio
Pardon my ignorance if this is out there somewhere in information space but I can’t find it. Is there anyone or anywhere that can list engine size to airplane weight? For example I would like to know just for knowledge sake the following
5lbs – 7lbs airplanes = .40 - .46 2 stroke or 52 – 72 4 stroke
8lbs – 10lbs airplane = .60 – 91 2 stroke or etcetera….
β€œβ€β€β€ β€˜β€β€β€β€β€β€β€β€β€ β€œβ€β€β€β€β€β€β€ β€˜ β€˜β€β€β€β€β€β€β€β€β€
β€œβ€β€β€β€β€β€β€c β€˜β€™β€™β€™β€™β€™β€™β€™β€™β€™ β€œβ€β€β€β€β€β€β€β€ β€˜β€™β€β€β€β€β€β€β€β€
Thx
Joey V.
Old 08-30-2007 | 03:29 PM
Default RE: weight to engine ratio
In general, that's a loaded question. For instance, a Cub can get by with a lot less power-to-weight (which I think is a more meaningful comparison, by the way) than a plane meant to be a 3D monster. For what it's worth, the numbers you listed are probably pretty close for a sport ship....maybe a bit on the anemic side, but plenty enough for flying.
Erik
