need tips
MO
Level flight will happen at a speed determined by what speed or throttle setting you trim for level flight usually around one third to one half throttle. make SURE it balances correctly front to back AND wing tip to wing tip. launch it straight out with wings level at half or just a little better than half throttle into the wind (this is not a good windy day airplane). don't turn until you are up a ways then turn with SMALL stick inputs. GOOD LUCK
try trimming for level with a few level glide tosses power off to get a nice straight glide this may help get you close to power on trim positions.
