DP Edge 540 >
DP Edge 540
DP Edge 540
Old 03-30-2003 | 01:34 PM
Default DP Edge 540
Iam ready to fly my DP Edge 540 but not sure if needs to be balaced inverted or right side up. It does seem to be different and the book says nothing besides start at 6" behind leading edge.
Old 03-30-2003 | 01:42 PM
MinnFlyer's Avatar
Default DP Edge 540
Consider whether there is more weight above or below the wing centerline. Balance it with the heavy side down.
Old 06-14-2003 | 09:19 PM
My Feedback: (16)
Default DP Edge 540
If you are at the CG point, balance is balance. You need to clear the landing gear so upside down may let you do that.
Old 06-27-2003 | 04:19 PM
Default DP 540 Edge
I have just finished and flown my DP 540, it has a BME-44 gas en gine with the tail feathers servo amid ships. I found that it flys best if the CG is 4 3/8" With that CG it flys like a dream. SWC
Old 06-27-2003 | 10:29 PM
My Feedback: (16)
Default DP Edge 540
Is the above mentioned CG forward of AFT.
Old 06-29-2003 | 08:04 PM
Default DP Edge 540
Foreward
Old 06-29-2003 | 09:00 PM
My Feedback: (16)
Default DP Edge 540
Once you get comfortable with your plane and how it responds, you may want to try to move the CG a little farther AFT. At least to the recommended CG point. Will filling your tank move the CG?
Old 06-29-2003 | 11:39 PM
David Cutler's Avatar
Default DP Edge 540
Just an observation . .
If you need to ask that, then you sound fairly new to flying, and an Edge will be a huge handful.
It might be worthwhile using very low rates on the controls, especially the ailerons and elevator, with high exponentials on each.
Also, make sure you err on the fast side when landing. Bouncing along the runway is a lot better than snapping inverted just before landing!
Just a thought!
Happy landings.
-David C.
Old 06-30-2003 | 12:01 AM
Default DP Edge 540
well I have flown thedge now for about 30 time and it hasnt snapped yet. I guess My inexperience of nearly 20 years is enough to ask a question like that to see what everyones ideals are.
Old 06-30-2003 | 12:07 AM
Default DP Edge 540
Thats OK then. It's a bit difficult to tell if you have been in the hobby for 20 years or 20 minutes.
And this is the beginners forum.
If, however, you had been a novice then my misplaced comments would have saved you a few hundred dollars.
I apologize.
-David C.
Old 07-01-2003 | 06:48 PM
Default DP Edge 540
I have the same plane, with a DA 50. Balanced it @ 6" per the plans and it was massively tail heavy and nearly re-kitted. Checked DP website, where he now recommends 5" balance point. Flies perfectly a shade back of 5". BTW, I hung it inverted for balancing, by mounting a small ply plate betweent the 2 bottom stringers.
