C G question
I checked my mini pulse xt on my new great planes c g stand its shows it needs weight in the front do you check your c g with the battery in or out and if the balance is off where do you usally start?
if you have a plastic spinner, you might be able to add a bit by upgrading to alluminum, it will cost you though
dont' forget that you check cg with the tank empty, just incase you didn't know
Austin
Austin
My Feedback: (12)
CA
I like to have a slight nose down attitude when setting C-O-G & adjust for my flying style
how far off are you? (recommended/actual)
the batt is your best bet for adjusting C-O-G
Move the battery and radio first. Sometimes on smaller planes you can get away with lighter servos and maybe a micro for the throttle. If the servo tray is behind the CG, this can help a bit. Get rid of the metal pushrods for the elevator and rudder. Only add weight as a last resort.
