 fuel question >
fuel question
fuel question
Old 11-19-2007 | 08:11 PM
Default fuel question
when the weather gets cooler i'm finding that i have to run my engine much richer for some reason and i'm burning 10% fuel. i'm wondring if changing to 15% would let me run it a bit more lean because its running warmer.
Old 11-19-2007 | 08:21 PM
w8ye's Avatar
My Feedback: (16)
Default RE: fuel question
15% would require you to be even more rich
Cold air has more density so you need more fuel to maintain the stoichiometric air-fuel ratio
Nitro has a lower stoichiometric ratio than Methanol. Therefore a greater percentage of nitro - you will have to open your needle valve more and get less economy.
Old 11-19-2007 | 08:24 PM
You are probably NOT actually running richer. Cold air is more dense and carries more oxygen. To compensate you needed to open your needle valve a bit more to obtain the SAME fuel to air ratio as before. Because you opened the needle you probably though you were making it richer but actually just returning it to where it belonged.
Old 11-19-2007 | 08:25 PM
so your suggesting that i stay to the 10%?......what are you using?
Old 11-19-2007 | 08:26 PM
w8ye's Avatar
My Feedback: (16)
I've used 15% winter summer for the last 4 years but I generally run four strokes
Old 11-19-2007 | 08:27 PM
it seems with the way i have tuned it now that i can't the rpm's to where they are when its warm
Old 11-19-2007 | 08:28 PM
well i just run two stroke engines.......i just got into this so i got a lot of learning to do
Old 11-19-2007 | 08:35 PM
w8ye's Avatar
My Feedback: (16)
The engine actually will make more power if you get the mixture right.
The last time I flew the temperature was around 36F at the beginning of the day and got up to about 54F. Those engines really ran good when you let them warm up a little.
Old 11-19-2007 | 08:38 PM
i'm really appreciating your help here w8ye..............you seem to have been around. glad i joined this forum
Old 11-19-2007 | 08:40 PM
so you guys do much flying in 0 degree celcius temps
Old 11-19-2007 | 08:41 PM
w8ye's Avatar
My Feedback: (16)
You build models 55 years and you will have a lot of the answers too.
Old 11-19-2007 | 08:45 PM
ORIGINAL: springhillflyer
We try not to.
Old 11-19-2007 | 08:48 PM
your a funny guy bruce............but when you live in canada the flying season would be too short if we didn't
Old 11-19-2007 | 08:52 PM
w8ye's Avatar
My Feedback: (16)
I used to before I was 30 but that was a few years back. If I get out there now in the 30's it's supposed to get up in the 50's by mid day. I lived in Alabama for 3 years in recent times and that's the usual temp in the dead throws of winter. Fly all year down there. The flying is done for me here in Ohio until March
Old 11-19-2007 | 08:55 PM
This is supposed to be fun. Freezing is NOT fun. Many in the Northern states do fly in the cold. Here in my part of Tennessee the cold doesn't last long enough to count.
Old 11-19-2007 | 09:01 PM
ok bruce, hang on.....i'm comin down there
Old 11-19-2007 | 09:26 PM
Did I mention the 100+ degrees fahrenheit summers?[:@]
Old 11-19-2007 | 09:33 PM
w8ye's Avatar
My Feedback: (16)
I remember being down south in July. Absolutely perfect flying conditions wind and rain wise but the Temperature in the high 90's and no wind with 90% or higher humidity. Hard to get your breath at times.
Thank goodness I could set in the shade of a building to fly.
Old 11-19-2007 | 09:43 PM
Yep, Houston (lived there for 10 years) is about the same as here except hotter and more humid. Both feel like a steam sauna in August.
Old 11-19-2007 | 10:32 PM
Sure, if its a nice day. Engines run better with more power and the planes fly better. Just get some good gloves or a transmitter mitt to keep the wind of your hands. Lighter fluid is helpful to start the engine. Batteries won't last as long in the cold though.
