 An old carb >
An old carb
An old carb
Old 11-26-2007 | 03:44 PM
Default An old carb
Hi its me again.
Another question this time about carbs, I have been given an old carb for my OS H 40P it is sticky and I can not move the throttle arm and what to know do I strip it and soak it or just soak it.
If stripping it is the option how do I start
Thanks David
Old 11-26-2007 | 04:19 PM
w8ye's Avatar
My Feedback: (16)
Default RE: An old carb
It just dried castor oil.
Soak it in something to loosen the dried crud.
Old 11-26-2007 | 04:30 PM
mscic-RCU's Avatar
soak it in some fuel.
Old 11-26-2007 | 06:12 PM
sometimes a little heat from an air gun will work if after soaking it still does not want to rotate.it also helps to remove the barrel stop screw .
Old 11-26-2007 | 08:06 PM
My Feedback: (27)
A dip in hot detergent (dish soap) and some movement should work well, a little oil will keep it loose until you use it.
Old 11-27-2007 | 12:40 AM
OzMo's Avatar
WD 40, fuel, soap, denatured alcohol. all will desolve the gelled castor oil don't force it though make sure the jets are clear by putting some fuel line on the input nipple with a little fuel and gently ...GENTLY!! blowing. if you blow to hard it'll go ALL OVER and glow fuel taste like/// glow fuel oh yeah unscrew the needle valve first
I would save yourself some head aches and get a new Oring for the needle valve as they don't last long and will drive you nuts with air leaks.
Old 11-28-2007 | 10:37 AM
