 Big stik 60 assembly and thoughts on my combo!! >
Old 12-12-2007 | 05:44 PM
Default Big stik 60 assembly and thoughts on my combo!!
I will start building my second plane, a Big stik 60, radio I will be using is a Specktrum DX-7, Nitro motor will be a OS FX 91 Lots of Power!! Does anybody have any sujjestions on this combo!!! If you have any building tips for the Big stik please let me know!!! My first plane was a park flyer I could fly it with my eyes closed> than I stepped up to a nexstar flew first time out the box by myself no problems snapped rolled it on the second pass first landing was a 10!!! Guys at the field couldn't believe it!!! I've been flying 182's and 210's since i was 12 the real thing so far this is a breeze!!! So i'm steping up hard and fast, fast being the main option!!!
Just need some tips on reinforcement and building an arf not much exsperience in building yet!!! SO i would greatly appreciate some advise on my combo, and assembly!!!
Thanks!!!!
Old 12-12-2007 | 06:03 PM
Default RE: Big stik 60 assembly and thoughts on my combo!!
Follow the instructions, dont rush things.
You will see that ARF's are pretty easy to assemble.
Most important thing to do since you are using the big engine is to set your CG as recommended. Since it will most likely be nose heavy, before adding the lead, first try moving the battery behind the servos and then add the lead..
Most important have funnnnn.
Old 12-12-2007 | 07:23 PM
bigedmustafa's Avatar
The Big Stik .60 is designed around a .61 2-stroke and your .91 FX weighs less than an ounce more than the .61 FX. Most Stik designs are very sturdy in design. Build it according to the directions and everything should come out right. My first ARF assembly was a Thunder Tiger Tiger Stick .40 and it was easy even though I was a first-timer. Great Planes ARFs have a terrific reputation for clear and thorough directions, so you should have little to worry about.
Good luck and have fun!
Old 12-12-2007 | 07:45 PM
w8ye's Avatar
My Feedback: (16)
Make it a tail dragger.
I flew mine for about five years before getting shot down
Old 12-12-2007 | 07:56 PM
My Feedback: (7)
Consider putting a Fults dual strut nose gear on it. These cost over $20.00 but the difference in ground handling will be amazing.
Old 12-12-2007 | 08:17 PM
I've flown with Fults nose gear before, they do rule. I thought the Big Stik .60 was a tail-dragger by default though, as opposed to the .40 which is tricycle gear. I could just be confused on this point, I've been taking a lot of cough medicine!
Edit - A quick visit to the Tower Hobbies website shows that tricycle gear is the default, but instructions are included for building it as a tail-dragger instead.
Old 12-12-2007 | 09:00 PM
Jester241's Avatar
I have a Big Stick .60 with a .90 super tiger on it,and its the best flying an most fun plane I own beyond a doubt! It should be mandatory for every r/c pilot to own one. And the .90 sized motor is PERFECT.....not overpowered,not under....just right. Well,at least it is with my .90 ST,your O.S. will likely have a bit more juice,but not much,it'll be fine. I built mine according to the manual and nothing has when wrong yet,just make sure you mount the wing halves together well,cause your gonna fly the crap out of it I'm sure. And personally,I recommend keeping the tricycle gear arrangement. If your like most of us,the next several planes you build will be taildraggers,so its nice to have a plane that not once in awhile,and your big stick will be an excellent "that" plane. Its also a very strong gear. I'm known for bending landing gears from my newb landing skills,and I've never bent my big sticks yet. I've considered switching mine over several times,but I just like it the way it is! The only reason I might in the future is to put skis on it. I think the Big Stick would also be a great plane for this.
Your really are going to love that plane!
Old 12-12-2007 | 11:49 PM
OzMo's Avatar
Look it over and consider reinforcing the firewall and landing gear area. I would go tail dragger. the fx 90 is a good motor has a history of being a little lean in the mid range so keep it a little richer than usual.
You can beat it with a stick, but you can't beat a stick!
Old 12-13-2007 | 05:41 AM
Jester241's Avatar
ORIGINAL: OzMo
Oh yeah,now that you mention it....my landing gear area DID crack on me sometime during the first couple flights. Epoxy the heck out of that area!!!
Old 12-16-2007 | 05:35 PM
Hello Everyone:
I'm gong to buy at Big Stik 60.
A couple of people in this thread have mentioned setting them up at tail draggers.
My question is, how is the tail wheel set up? Is a hole cut in the elevator and a wire run down from the rudder to the tail wheel or what other way is the the tail wheel controlled?
Any information will be most helpful.
Bye, Ian
Old 12-16-2007 | 06:35 PM
http://www3.towerhobbies.com/cgi-bin...?&I=LXHDJ3&P=7
Use one of these or something similar.
