inverted OS 46 AX engine
does anybody know how well the OS 46AX engine runs if it's mounted inverted?
have you ever used one inverted and how did it run?
hulio
hulio
IN
I ran an inverted OS 46 AX all last year without any problems. It ran fine with the standard glow plug. I did add a step to my startup procedure to always flip the prop once after priming the engine and after energizing the glow plug before using the electric starter. Straight upside down with the stock muffler.
I ran one in a Flip 3D and had no problems. If you use an electric starter, then there's really no need to prime it. Just make sure the center of your tank is even with the center of the carb, and it should run just as well as it does on its side or upright. I've never had to run an idlebar plug in my AX or my FX. Just my 4 strokes.
NY
Someone whom I regard very knowledgeable, mentioned when looking at an inverted engine, that it might be a good idea to have such engines mounted a few degrees off so that excess fuel does not pool at the lowest point and flood the glow plug . As alternative start them with the plane upside down. In how far this is valid I do not know, but it seems to be logical.
ORIGINAL: broke_n_bummin
