 balancing issues with extra 260 >
Old 01-16-2008 | 09:43 PM
Default balancing issues with extra 260
hey everyone, im trying to balance my .91 extra 260 but i've got a problem. i've already added 3 oz of weight to the inside of the cowl, and the center of gravity is still about 3/4" rear of where it should be with a half tank of fuel. is this close enough? i do want it a little tail heavy, but im not sure how much i should go for sport flying. any suggestions would be greatly appreciated!!
eric
Old 01-16-2008 | 09:51 PM
bingo field's Avatar
Default RE: balancing issues with extra 260
get rid of the fuel, it should be empty. start the cg where the mfg. suggests, and move it back slowly after you fly it to see where Your model flys best for you. it is the safe way to do it. patience....
good luck
Old 01-16-2008 | 09:53 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Bingo is absolutely correct. The plane needs to be balanced with the fuel tank empty.
Ken
Old 01-16-2008 | 09:55 PM
its been a while, but is it ok to add weight to the inside of the nosecone?
Old 01-16-2008 | 10:14 PM
RCKen's Avatar
My Feedback: (9)
If you're referring to the spinner, it's not the best of ideas. Since it's spinning any weight needs to be done so that it's balanced. Otherwise you will get the spinner off balance at the least can cause the plane to go out of control and at the most damage the engine and the airframe.
Ken
Old 01-16-2008 | 10:31 PM
MinnFlyer's Avatar
Not to mention the fact that the badly unbalanced spinner will soon break, fly off and leave you with a very tail-heavy airplane.
Old 01-17-2008 | 11:50 AM
MasterAlex's Avatar
Here's some "functional" weight on the nose, if you don't mind loosing the look of the spinner. [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXL729&P=7]Heavy Hub[/link]
Determine proper size based on your engine. That get's the weight as far forward as possible. Maybe this helps?
-MA
Old 01-17-2008 | 03:34 PM
ok as everyone has said balance with an empty tank...
As this is a low wing airplane are you balancing upside down? You should be...
Old 01-17-2008 | 04:46 PM
no i balanced the plane right side up, the wing is pretty much in the center though. i just checked it again, when it is upside down it is noseheavy and when it is right side up it is tail heavy... hmmmm.... i haven't been flying in about 3 years so i'm pretty rusty as far as remembering all of the precedures for balancing. all help and replys are appreciated though!!!!!!!!!!!!!!
also the weight i have been adding is to the inside of the cowl, that shouldn't cause any issues should it?
Old 01-17-2008 | 05:18 PM
Mr67Stang's Avatar
When you need nose weight the only option is a bigger engine... at least that's what I tell my wife
Old 01-17-2008 | 09:48 PM
Stang i tryed that a few times with my wife an it worked great. Then one day she got on towers web site an things haven't been the same since. She found that 40oz of stick on lead was alot cheaper than 40oz of bolt-on O.S. I told her they may fall off if fuel soked,so she showed me how to drill a hole in them an mount them. From that day on its been just moderate powered models
