 Prop Basics >
Prop Basics
Prop Basics
Old 03-08-2008 | 04:57 PM
Default Prop Basics
Hi,
I came across a PDF doc on the [link=http://www.masterairscrew.com]Master Airscrew website[/link] and thought it does a good job explaining some prop basics. This is good, slightly more technical info for beginners to make more sense of the elusive question of "Which prop to use?".
http://00e2fac.netsolstores.com/imag...ler%20info.pdf
There are a few other PDF's on the site also... like one which contains the usual generalized prop size tables. That document also contains a formula for estimating max rpm when using nylon props which I thought is probably a very useful starting point... the formula:
RPM Operating Limit (for nylon props) = 165,000 divided by Diameter in Inches
Just thought I'd throw that out there. I thought it was a good find and clarified some things for me.
Cheers
Old 03-08-2008 | 06:45 PM
Default RE: Prop Basics
just as a heads up
For apc max rpm = 190 000/ prop Dia. (inches)
Steven
Old 03-08-2008 | 06:56 PM
ORIGINAL: Flying freak
just as a heads up
For apc max rpm = 190/ prop Dia. (inches)
Steven
Do you mean that max RPM for a 10 inch APC is only 19 RPM? Doesn't seem worth the trouble of starting the engine does it? Why do I think you mean 190,000/Dia (inches).
Old 03-08-2008 | 10:18 PM
ORIGINAL: bruce88123
just as a heads up
Steven
At least one of us was paying attention
Thanx for catching that one I fixed the post
Steven
