What Prop For This Combo?
PA
Hello all,
I've got this setup:
CMP Katana 50 ARF
Magnum XL-70RFS 4-Stroke
What prop do you recommend for this combo.
I know it's large diameter, low pitch but I'm not exactly sure on this one
I would like to use the PowerPoint wooden props so I just need to know specifically what size
CMP Katana 50 ARF
You're going to want to start with a smaller diameter prop until you get a couple of gallons through the .70 RFS to get the ring nice and set. Start with a 13x4 or 13x5 and then move to a 14" prop once you've got a good, reliable idle established.
Once broken in, Flying Freak's suggestion of a 14x4 will be an excellent choice for 3D acrobatics.
Very good point,
For break in take a bit of the load off
try not to get the rpm higher than say 13k on the ground personally id try and keep it around 12k 4 strokes have LOTS of moving parts (compare to 2 strokes) and thus you dont want them to spin too fast
Steven
Steven
