engine trouble
mine was running fine for 2 months, then one week it did the same was actually the fuel. It could be a few reasons, im new at it still so someone else will help better, but one could be it might be running rich, and its filling up with fuel.
ORIGINAL: Exile182
Could be the fuel too. Unless you''re sure that you''re fuel is good, try changing that first.
OR
Hey thanks everyone.I''ll try it all.Its nice to get outside perspectives.I was thinking it was running lean on the low end for whatever reason but was not sure. Thanks guys
May be rich on low end. Turn lo needle 1-16 turn clockwise and see if it works better. Rich low-end causes fuel to pool in the crankcase and douses out glow plug when throttle is opened. Usually, as an engine breaks-in it needs a less rich mixture to run well. Ross
